10" subs for trunk???
Username: Jaackdeth
Burnett, WI United States
Post Number: 63
Question for anyone. I listen to more like Slip Knot, Korn that type of music, some rap. I have a caddy, and I need something to pound through the trunk. I have a Hifonics 1500 amp right now to run subs off, suggestions?? Thanks!
Username: Dpaw20
FL USA
Post Number: 278
2 10" eclipse ti's
Username: Sploosh56
Ohio
Post Number: 669
and port them. 35 hz
Username: Jaackdeth
Post Number: 65
Will the 10's be good for what I listen to you think? Thanks
Username: Sploosh56
Ohio
Post Number: 670
i've got a pair pf 10" infinity reference subs and korn sounds f*cking awesome. as well as slipknot, disturbed, snot, godsmack. all that good stuff.
Username: Jaackdeth
Post Number: 66
Ok, thanks man!
Username: Taylor17
Kopperl, Texas
Post Number: 2273
As long as you're willing to spend that, the Eclipse TI's are perfect!
Username: Jaackdeth
Post Number: 67
LOL, I just checked out the price!! Any other (lower price) anyone? Are L7's any good?
I'm new at this, so any input is appreciated. Oh and don't forget to figure in my amp! Thanks~
Username: Sploosh56
Ohio
Post Number: 671
how much do you wanna spend on subs?
Username: Sploosh56
Ohio
Post Number: 672
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=3291%26item%3D5783789609% 26
check them out. see if ya like them. those sound pretty good and get loud as well
Username: Jaackdeth
Post Number: 68
never heard of them, but I would take your word on it. that is about my price range, maybe a little more, but I see this dude has only 1?
Username: Sploosh56
Ohio
Post Number: 673
heere's my aim name
Sploosh56
IM me on there and we'll figure it out
Username: Sploosh56
Ohio
Post Number: 674
http://www.sonicelectronix.com/item_4240.html
Username: Jaackdeth
Post Number: 69
Man I see that guy has just one of those also. I don't have aim, anything other?
Username: Sploosh56
Ohio
Post Number: 675
that sub hits hard. sounds really goof with rock and rap.
Username: Sploosh56
Ohio
Post Number: 676
that sub hits hard. sounds really good with rock and rap.
Username: Jaackdeth
Post Number: 70
I believe it, again another first, Dual 1 ohm VC, getting an education here! Ya think 1 is going to do it though in a trunk of a caddy?
Username: Sploosh56
Ohio
Post Number: 677
one of them will in a ported box will sound pretty good. i'd go with two personally
Username: Jaackdeth
Post Number: 73
yeah I think I would want to go with a pair also, now to find some, or the PPI's
Username: Sploosh56
Ohio
Post Number: 679
you can buy them off that site. sonicelectronix is a legitamate site
Username: Jaackdeth
Post Number: 74
dumb question coming here, how would i wire 2 of them to get 1 ohm? That is where all the power of that amp is at
Username: Sploosh56
Ohio
Post Number: 680
since them subs are dual 1 ohm wire each sub up so that it represents a 2 ohm load (wire it in series). then take each sub and wire it together to present the 1 ohm load ( parralel wire it) you are looking for.
Username: Araknid
BOCA , FL U.S.
Post Number: 767
You would need 2 DVC 4ohm subs to get a 1ohm load with them wired in parallel.
Username: Sploosh56
Ohio
Post Number: 681
you wire the coils on each sub in series. then wire the subs togethor by parralel
Username: Araknid
BOCA , FL U.S.
Post Number: 768
oh well if your you have to use DVC 1 ohm subs that will work to.
Username: Jaackdeth
Post Number: 75
Anything on here to show that? http://www.jlaudio.com/tutorials/wiring/index.html#2dvcsp
Username: Araknid
BOCA , FL U.S.
Post Number: 769
thats the one.
Username: Sploosh56
Ohio
Post Number: 682
that is what you need right there
Username: Jaackdeth
Post Number: 76
Ok, so that set-up will give me a 1ohm load at the amp? if I have 2subs with dual 1ohm coils. Just dbl checking, and thanks guys!!
Username: Jaackdeth
Post Number: 77
One last thing, you did say a ported/slot box correct?
Username: Sploosh56
Ohio
Post Number: 683
yep. make a ported/vented box tuned to 35hz
Username: Jaackdeth
Post Number: 78
And that will give me 1ohm at the amp? Now I'll leave you alone and thanks man, I really appreciate all the help!!
Username: Sploosh56
Ohio
Post Number: 684
yea no problem.
