6.5 inch speakers
Hoover
Just got a 1997 Saturn sc2 and im working on the audio system...I have a lanzar 1200 watt amp with 2 Jl 12" W3's...the door and rear deck speakers are 6.5....my head unit puts out 45 watts to each speaker..what would be the best way to go with 45 watts of power if money were...and werenot an option?
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 1774
ok the head unit may be 45Wx4 max, but no WAY is that RMS. real power is about 11 watts x 4.
if you want about 45W x 4 real power, look at the JBL P80.4 amplifier as an inexpensive solution, or a Kicker amp similar to the KX600.4 (75Wx4) if you can spend more
