Please Help Can The Remote On blue wire be connected to the cig lighter as that only works when the key is in the switch thanks
milo 2005
Username: Thrushdtd
New York
Post Number: 144
yes that will work fine i did that for a little while before i baught a new head unit.
Username: Thrushdtd
New York
Post Number: 145
just make sure you attach it to the wire in the back
