Dual 4ohm Type R ok for........?
Username: Safa19
Post Number: 79
would the dual 4 ohm type R sub be good for the orion 600D amp that is 600watts rms at 1ohm or should i get the dual 2ohm sub? whats the difference if im running it at 1ohm?
Username: Thrushdtd
New York
Post Number: 139
if your only getting one sub you want the dual 2 ohm and wire it in parellel to get a 1 ohm load but if your getting two subs to the single amp you want the dual 4 ohm wired in parellel and parellel again.
