What gauge wire?
Username: Cajun74
Post Number: 16
What gauge speaker wire is recommended from the amp to the sub. the amp puts out 400rms at 1ohm and the sub is a jl 12w3 D2. Thanks for any replys.
Username: Iufan4lifeul
Louisville, Kentucky
Post Number: 149
I ran 18 gauge, works fine for me. I have 2 subs that are being run at 400rms apeice. Hope that helps.
Username: Cenus
Hicksville, Ohio Usa
Post Number: 242
anything between 12-20 gauge wire should do fine.
Username: Geekbike
Post Number: 201
I personally wouldn't use anything less than 10 gauge. Otherwise you're running the risk of having it short and light you car on fire from the inside.
Chart here:
http://www.the12volt.com/info/recwirsz.asp
