Amp-500wrms.. subs 800wrms
Username: Iowahawks19
Post Number: 16
am i underpowering them too much??
btw-mtx801d amp
2kicker cvr's
Username: Alpineuser
Winchester, TN
Post Number: 585
i thought the 801 produced 800watts @ 2 ohms
Billup
i have those same subs with about 500 rms and they sound alright but they definetley are capable of taking some more power and im looking inot getting a new amp soon
Username: Taylor17
Kopperl, Texas
Post Number: 2252
That set up is perfect for them. Each sub should be getting 400 watts rms.
Post Number: 17
the 801 puts out 800watts@2 ohms but thats rated at 14.4 volts
the 500w rms is at 12 volts and thats what my car puts out i believe
Username: Taylor17
Kopperl, Texas
Post Number: 2253
I wouldn't think the power would brop that much... more like 650/700 watts. Where did you find that rating?
Post Number: 18
ive been doing some research(local audio shops) also ebay and i saw a picture of the specs and it said
1x500w @2ohms rms @12.4
1x800w @2ohms dynamic power @14.4
btw what does dynamic power mean?
Post Number: 20
also i can pick that amp up for about 200$ off of ebay.. and can get it from a shop for 270$-NEW is it worth the extra 70$ to go used( im on a tight budget so every little bit counts)
