A "Real" Enclosure Question
Username: Kd7nfr
Montpelier, ID United States
Post Number: 155
I'm playing with WinISD, and I have a question. What is a good -3db cutoff point? What is the lowest frequency music goes? Also, what is a good top frequency for a sub? I'm trying to get this box PERFECT!
Username: Voodoochilde
Greencastle, Indiana
Post Number: 49
I think the lowest the human ear can hear is 10hz....So I definately wouldn't worry about anything that low.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 7863
lowest you should worry about is ~20Hz
good crossover point for subs is 50-80dB depending on the sub and it's size.
Tuning ports will depend on the Fs of the driver, and your goals.
Username: Geekbike
Post Number: 155
Human hearing cuts off right around 20hz, and not many mainstream songs will go that low. Where the -3db should be is dependant on the slope of the enclosure you are using. Sealed boxes are generally about 12db/octave whereas ported is around 20-24db/octave. If you keep the F3 around the 30hz mark for ported and around 40hz for sealed, it generally gives good results. As for top frequency, the stength and cutoff of your midbass will determine it.
But be reminded, all of this is subjective and you may not like the sound. You need to experiment and see what you think sounds best.
Username: 54danny54
Post Number: 446
OMFG glass wolf finnaly posted
Username: Kd7nfr
Post Number: 159
What do you mean F3?
