Diamond Audio TDX or M6
Username: Transamkid2000
Post Number: 24
What is better for SPL. 2 12" Diamond audio TDX12, or 2 12" Diamond audio M6. Each will b given 600 watts rms and is in a sealed box
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=12446
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=12444
isnt underdriving a sub bad? (tdx wants 1500 rms each)
Username: Araknid
BOCA , FL U.S.
Post Number: 678
No Underpowering a sub is not bad for the sub if thats what you mean but yeah it wont perform the way it was meant to be if you consider that bad. I mean well if you underpower it by alot. The least amount I would want to give a 1500 watt Rms sub would be like 1100.
Username: Araknid
BOCA , FL U.S.
Post Number: 679
Oh I forgot to ask whats the RMS on the M6?
Post Number: 25
rms on m6 is 800 in a 2ohm load or 4ohm load
Username: Hdubb
Farmington, Nm Usa
Post Number: 1773
id go the m6
Post Number: 26
good call man, good call...i saw a guy with a 1350 watts rms amp, 2 12" m6's in a sealed box hit 144.2 db in the trunk of a bonneville
his system also ran at 14.0 volts the whole time...so im assuming keeping the voltage up helped a lot
Username: Hdubb
Farmington, Nm Usa
Post Number: 1775
yeah ive know there is one here that does 146 but not sure on what mic(i know its not tl)
Username: Araknid
BOCA , FL U.S.
Post Number: 680
I got some questions for you but I g2g to the airport so ill find out later.
Username: Hdubb
Farmington, Nm Usa
Post Number: 1778
for me? or mikey m?
Username: Araknid
BOCA , FL U.S.
Post Number: 681
I just got back had to drop off my cuz. I need to know what amp your goin to use mikey.
Post Number: 27
im using this one...
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14132
PG xenon 1200.1 rms @ 1-4 ohms
so that will b powering 2 Diamond audio M6 12 incher's
Username: Araknid
BOCA , FL U.S.
Post Number: 683
Yeah given the amount of power you have to work with the M6 would be a better choice.
Post Number: 31
thanks bro..will do...i hope they out pound the W7's i had (10w7)
