What size screw for box??
Da Ali G
what size screws do i use for a sub box?
Username: Thrushdtd
New York
Post Number: 47
inch and a quarter
Username: Geekbike
Post Number: 136
I use 2.5" drywall screws. Make sure you predrill the holes to avoid splitting the wood.
Username: Audio_king
Denton, TX USA
Post Number: 11
i use brad nails and wood glue to build a box...or r u putting subs in a box and need to secure them down? if so those guys r both right.
Username: Disturbedpriest
Post Number: 130
make sure you put them all in the sub though i just put four to demo my diamond a few days ago and it blew out the f_cking enclosure.. i said oops :-)
Post Number: 131
as in the sub blew itself out of the enclosure my bad its 5 am and i am a lil tired. :-)
Username: Alpineuser
Winchester, TN
Post Number: 455
well most countersink kits will only go to 1 5/8" so that will be plenty long. just remember to use wood glue because the screws really arent what holds it together it is the glue. the screws just hold it together so the glue can dry, and also run a bead of silicone on the inside seams just to make sure everything is air tight
Username: James1115
Wilton, Ct
Post Number: 3338
I am a big fan of the 2.5in dry wall screws with tons of glue and yes the silicone is key but dont put the sub in the enclosure untill the silicone is dry it releases vapors while it is curing that will deteriorate the subs surround if it isnt dry.
