i finally found out what was the problem with my jl 2 12 w3v2. the box i have is not completly sealed when the guy built the box he made everything flush and mounted the amo to the box and he forgot to seal the holes he drilled for the cables. does anyone know what i should use to seal the holes that are running my cables.
this is a professional that built this and he didnt use a terminal? this is what you should do. buy a terminal and cut out the diameter of it in your box plop it in screw and then you will be ok.
i agree that is what the guy should have done in the first place. i had a 1500.00 install and the lazy bastages took the same shortcut w/me. you could just use caulk/sealant from home depot though. they can refer you to the correct type.
lol whatevr they can do to cut corners i guess, but i was wondering what can i do if they power wires and rca are going through the box onto the amp mounted to the front of the box. i'm thinking of using some kind of sealent like you suggested or can i use a terminal for the power cables
ok this is what you do bring that box back call him a f*cking moron and build a new one, or go to a different shop maybe some that know what they are doing. there are some people from florida on this board that could help you build it or find a good shop. apacalypse is one and there a lot more. just ask. i cant believe that though. that pis.ses me off
