Amp question
Username: Bus212
Kingsford, Michigan Us
Hey i just bought two 12 inch kicker subs, and i bought an amp today a 300 watt pioneer GM-3100T. has anyone ever used this amp before and do you think it will do the job? Thanks
Username: Solacedagony
New Jersey US
Post Number: 465
Depends what 2 subs you have. I doubt 300W will be enough though.
Username: Byrumjr
Post Number: 291
The pioneer GM-3100T, they say will it will push 150 watts RMS at 4ohms bridged. Without knowing the model of the sub or the RMS watts it will be hard to say. You can run one sub at 4ohms bridged and it should sound ok. You can run both subs but you will have to run one sub on each channel. This will give less watts than when bridged. Each sub will get Continuous Power: (4 ohm)60W x 2 and Continuous Power (2 ohm): 75W x 2. For most subs to sound good and hit hard you need to get in the upper ¾ of the RMS watts.
Username: Bus212
o ok whats an amp that cheaper that will run them good then?
Username: Thrushdtd
New York
Post Number: 26
what is the model and impedancy of subs?
Username: Bus212
im not exactly sure to be honost there my sis boyfreinds old kickers there prolly about 2 years old.
