Caps
mr. dumb
what the heck is a "cap"
mr. dumb
oh ya and what happens if you dont upgrade ur alternator? and how much does it cost? and how much would be a rediculouse amount? (500amp alternator as an exsample)
Username: Lowrollins10
Champaign, IL
Post Number: 102
A "cap" is a capacitor wich is like a battery but can charge and uncharge very fast. Used for instant power to your amplifier.
If you dont upgrade your alternator the constant stress will cause premature failure.
Powermaster makes good alternators along with Stinger.
They dont make a 500 AMP alternator or at least I have never seen one. 325 is among the highest. wich can cost around 300 bucks
mr. dumb
ya i was kinda being sarcasitc with the 500amp, but a "cap" is just an upgraded alternator
Champaign, IL
Post Number: 104
no a cap is a capacitor looks likea little round cylinder that holds a charge like a battery.
Username: Solacedagony
New Jersey US
Post Number: 460
A capacitor is wired into your power wire before the amp. When your amp needs a large amount of power at once, your capacitor will discharge so the amp will get what it needs. It makes sure your voltage doesn't sag.
Although if you have a capable alt, you really shouldn't have to worry much about that anyway.
