Silver Member Username: 54danny54Post Number: 361 Registered: Nov-04 | ok i have 2 questions...and i need alot of help answering. 1)Does any1 know or can find out the noise ordinace thing in KY 2)Whats yall's opinion on this sub http://www.visonikcaraudio.com/sub/products/subwoofers_2.html im thinkin of goin with 3 10's with a Hifonics brutus 1500D |
Silver Member Username: Alias747MN Post Number: 198 Registered: Apr-05 | A brutus 1500D will only put out MAYBE 675 watts rms at 2.67 ohms. If you were getting 3 of those 4 ohm DVC subs, that is the only way you could wire those subs. Not much power, you would be under running them quite a bit. |
Silver Member Username: 54danny54Post Number: 363 Registered: Nov-04 | well i meant if te was an option 2 run it a 1 ohm and does any1 know the noise ordiance thing in KY |
Silver Member Username: 54danny54Post Number: 368 Registered: Nov-04 | bump |
Silver Member Username: Addicted2bassMiami, Florida USA Post Number: 812 Registered: Nov-04 | hey Donny do you have those subs already...If not i recommend getting different subs. |
Silver Member Username: 54danny54Post Number: 370 Registered: Nov-04 | lol u know i dont...im either gettin a couple of them or a 15 inch H2 |
