Username: Langner Madison,
South dakota
US
Post Number: 146 Registered: Apr-05
Monday, June 06, 2005 - 14:40 GMT I was just wondering what i could use for sound damping i dont want to use dynamat because i dont want to pay that much n put all that into the pos car that i drive so is there something cheap that would work and make my trunk not rattle as much?
Username: Jeremyc Germany
Post Number: 716 Registered: Jun-04
Monday, June 06, 2005 - 14:55 GMT peal and seal from home depo works well and is real cheap e-dead / hushmat / are some other brands like dynamat that are cheaper and work well. Lets see I have even used floor carpet padding in a trunk before with some high temp spray adheasive.
moe joe
Wednesday, June 08, 2005 - 04:13 GMT i used some old 'clean' socks to stuff some rattling panels.. :D
xdrummer03
Wednesday, June 08, 2005 - 06:21 GMT $35 for a 4sq ft roll of dynamat. Doesnt matter how much car is worth,its how much sound it worth to you.
