New member Username: Arrap69Riverside, CA. USA Post Number: 9 Registered: May-05 | Going to purchase MTX Subs for 2002 Silverado ( http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem%26item%3D7978566965&cat egory=38647 ). Which MTX Amp. would you suggest? This one: http://www.woofersetc.com/product.asp?0=362&1=363&3=2166 or This one: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=64573%26item%3D5779909150 &tc=photo Any other Ideas? (keeping stock HU and stock comps.) Thanks! |
Silver Member Username: ByrumjrPost Number: 279 Registered: Jan-05 | The sub link did not show. So I don't know if they DVC or SVC or the ohms and RMS watts. For the price I would go with the MTX THUNDER 2301 AMPLIFIER MONO BLOCK AMP TA2301 NEW 05 300 RMS @ 2ohms if you sub matches this. |
New member Username: Arrap69Riverside, CA. USA Post Number: 10 Registered: May-05 | MTX 4500 10" Subwoofers Frequency Response: 35Hz-150Hz Magnet Weight: 30 Oz Efficiency: 90.7dB Impedance: Single 4 Ohm RMS Power Handling: 450 Watts Peak Power Handling: 900 Watts Try this link: http://search.stores.ebay.com/search/search.dll?query=CXP20C&srchdesc=y&sid=2716 2071&store=HiFi+Sound+Connection+Car+Audio&colorid=6&fp=0&st=2&submit=Search |
Gold Member Username: Taylor17Kopperl, Texas Post Number: 1978 Registered: Jan-05 | I posted in the amp section. |
Bronze Member Username: AdampitPost Number: 63 Registered: Dec-04 | Just for your information, on the mtx site it tells you subs and amp and what combos work best using all mtx stuff |
