Loudest and Clearest?????
I just bought a piar of mtx 15 inch thunder 9500 subwoofers, powered by two mtx 801d amps. Now it is time to replace my stock door and rear speakers with components. I would like to stay with mtx just so all my subs and amps match. Does anyone have any comments on mtx components, good or bad? I am looking for something really loud and clear, with minimum distortion at high volumes. Would mtx components be capible of that? If not than what components would you recomend? I have a $600.00 dollar ball park range. My speakers are 6.5 inch front, and back. Thanks...
Username: Mikechec9
Chicago/atlanta
Post Number: 153
MINIMUM distortion at high volumes calls for more than mtx can serve up.
DLS
CDT
Focal
DYN
