Gaming systems question
Username: Crazyred
Baker, Louisiana United states
Post Number: 20
im planing to get a xbox or ps2 in my car and i was wondering do i have to get a amp to power it
Dominic Aka Bullet
no you need a power inverter
Username: Climbamtn
Seattle, Wa Usa
if you dont have a preferance already choose the ps2. the xbox can not be mouned on its side and overheats quickly if in confined space. and yes all you need is a power inverter, get one that is 150 watts or as close to that as possible. the 115-120 watt inverters will burn up quickly as they would be running at peak.
