Billup Unregistered guest | Ive been talking to a couple friends at work and some have said i might be better off with two 10's in my car instead of 2 12's. I have a 1999 ford escort and 2 12" kicker comp vr's right now hooked up to a shiity "1200" watt Sony amp that probably puts out around 400-500 rms. Just wondering if anyone thinks i should go to 2 10's instead or if i should stick with the 12's. If anyone has an idea for an amp that will hit the 12's alot better let me know as well...thanks |
Silver Member Username: 54danny54Post Number: 369 Registered: Nov-04 | get u a new amp and stick with the 12's |
Billup Unregistered guest | yeah thats what i was planning on doing but im stuck with that amp for a while, any suggestions on my next amp |
Silver Member Username: 54danny54Post Number: 373 Registered: Nov-04 | whats the Ohms |
Silver Member Username: 54danny54Post Number: 374 Registered: Nov-04 | if its dual 2 ohm the go with http://www.woofersetc.com/product.asp?0=295&1=296&3=113 |
