What is the difference between the amp classes
ward
I just bought a kicker kx350.2 to power my infinity kappa perfect sub and am now worryed that I messed up because it is not a class d. I don't know what that means and want to figure out if i am royally screwed? I also want to know if it still puts out 350 rms with a 12 volt alternator?
Username: Byrumjr
Post Number: 265
http://www.crutchfieldadvisor.com/learningcenter/car/amplifiers_faq.html
read all this it will help you a lot.
Username: Ward
Chevy Chase, Maryland
thank you
but what about the 12 volt question
Username: Invain
Michigan United States
Post Number: 2805
I hope your altenator puts out atleast 12 volts, or it wouldn't be charging your battery...
Yes, all alternators run at a minimum of 12 volts. The higher you rev the car, the more voltage the alt. produces. Usually between 12 - 14 volts.
Username: Ward
but what about the specs on the amp. it says at 14.4 volts so if the alternator is 12 volt it won't put out as much power
Username: Invain
Post Number: 2809
Noo, they only measured the wattage of the amp at 14 volts. When your car is off, your only getting power from your battery, wich is 12 volts. It would be pretty silly if you couldn't play your system with the car off, woulnd't it?
