SUBFANIC help plz with eclipse neone
Username: Poof
Post Number: 42
hey i am looking at eclipse subs to put in a 2nd car... its a hatch back so i figured i could spend less $ to get same sound ne ways i was looking at the SW6123DVC eclipse 12' sub and i was also looking at the jl audio 12w3v3 i need an opinion on these 2 subs and what would "sound" better in sq....... also i want to stay under 200$-230$ per sub so if the eclipse 7 series is better tell me? thnx
Username: Poof
Post Number: 43
neone?
Username: 54danny54
Post Number: 314
Eclipse aluminum sounds better thne the JL i think
Username: Invain
Michigan United States
Post Number: 2774
The SW6100's aren't aluminum though... they're a composite alloy. Go find one and feel the cone some time, it feels like a vinyl or plastic.
You should get the SW7100 series, which are the Aluminum's. You'll pay more, but it's worth it.
Username: Subfanatic
Walton, Ky
Post Number: 4081
230 per sub would put you with a 10 inch eclipse al 88100 series, GO WITH THOSE FOR SURE!!!
