Hu settings???
Username: Subfanatic
Walton, Ky
Post Number: 3898
guys im wondering, right now all i have is my fronts, no rears, no subs, im waiting on new wiring to hook anything up, but thats besides the point, im wondering guys, what does LPF, HPF and Mid do, howshould i set these, oh and ND settings, LPF goes like lower, like i push back HPF goes higher, i push forward? what are these??? and how should i set these???
Username: Illuminator
Post Number: 379
LPF=Low pass filter HPF=High pass filter. They're just crossover options...with it you can make it so only certain frequencies above or below a set frequency can pass through the filter...
Walton, Ky
Post Number: 3904
what would you suggest i set them at
Post Number: 382
If you're only running the fronts, you probably want full range sound...so set it to anything but LPF or HPF...the Mid setting should put out full range.
Are those the only three settings? HPF,LPF, and Mid?
Walton, Ky
Post Number: 3919
no there are alot, i just didnt know what those were
