Anonymous | i was thinking of getting 2 10 " cvrs in a ported box for 219$ but i think i could get a nice 12" sub that would be better in spl and sq than the two 10" subs lemme know what u guys think i have a kicker kx400.1 amp so the sub should preferably be 2 ohm any suggestions at all would be appriciated or would i be better off with the 2 kickers i have a escort station wagon and am going for high spl but decent to good sq like 60 40 % should the sub be sealed or ported and why do u recommend it ex. u have it heard it compared etc.. thanks a bunch |
Anonymous | 219$for those subs is a little high even with the box included.. look for a package deal for like 130$ for subs... prefab box 50$ and right there you saved yourself 40$-- |
Silver Member Username: Fastbastard1977Lousiville, Ky Usa Post Number: 144 Registered: May-05 | http://www.caraudiodeals.com/product_info.php?cPath=35&products_id=35 check these out i put these in my wife blazer and they hit hard fot the price and there peing powered with this cheap a$$ AMP AND IT SOUNDS GOOD http://www.caraudiodeals.com/product_info.php?cPath=28_30&products_id=76 |
