I just want to make sure
Username: Theceo
Post Number: 50
i just wanted to make sure before i did this that it would not drain my battery, im going to hook up a 300w kenwood amp to my car, but i already have a 600w hifonics amp w/2 subs connected. having these 2 amps connected wont drain my battery will it?
Username: Illuminator
Post Number: 383
If those wattage specs are both RMS handling:130 amps total plus about 40 for the other electrical.
If those are max handling: 65 amps plus 40.
Either way, if you don't have a high output alternator, you might want to look into upgrading before hooking up the Kenwood.
