One channel blown?
LES
I have a fosgate 800 watt amp, older model. Its a 2 channel amp and one channel isnt working. My question is can i still brige the power, just take one positive from one channel and a negative from the other and still get it to use peak power? Im guessing it also has to do with what is blown in the amp... any advice?
Username: Mikechec9
Chicago/atlanta
Post Number: 99
i just posted on a similar issue w/my older RF. it blew my components. i wouldn't mess with a defective amp unless you have some wildabeast xplodes to test it on.
not sure how it's possible to bridge two channels if only one channel is operating. wouldn't be a bridge.
Username: Alastaka
Post Number: 71
you cant i did the same thing but mine was due to wiring wrong any way one channel gone you cant bridge and id be carefull or you ll kill the whole amp as i did haha
