Is it worth it????????????????????????????
Username: Cenus
Hicksville, Ohio Usa
Post Number: 139
is the ss box really good, how is it better than other boxes, and are they sealed or ported, i just can't see spend $300 plus on a enclosure when the subs only costed $250
Username: Araknid
BOCA , FL U.S.
Post Number: 581
That depends on you, do you really want to spend 300 dollars to get alittle louder?
Username: Cenus
Post Number: 140
me personally no i don't see why anyone would spend that much money on a box espically when it costs more than the subs
Username: Araknid
BOCA , FL U.S.
Post Number: 585
Theres your answer.
Username: Araknid
BOCA , FL U.S.
Post Number: 586
I mean sure if your competing or you have nothing else to spend the money on then why not.
Username: Cenus
Post Number: 141
well do you know where i can find a nice box for 2 15inch atlas's dimensions have to be smaller than 24inches wide/40inchs length/ 20inchs high
