Jl w7 13.5 truble
any ideas
i have a jl w7 13.5 i put it in a sealed box and have a jl 1000/1 running to it and i loose volts like cazy and then after a hour or 30 min of hevey play the amp thermal light comes on, now i took the sub out and am running a biger system so it not the power. any one ever have this problem?
Username: Addicted2bass
Miami, FLORIDA USA
Post Number: 688
does your lights dim?
Username: James1115
Wilton, Ct
Post Number: 3175
thats what I was thinking to bass, I dont really know what he means by he is running a bigger system now though, is it still happening with the bigger system?
Username: Jonathan_f
GA USA
Post Number: 3956
How did you have the subwoofer wired? You didn't have it in parallel, did you? Agree with above, describe the bigger system.
Username: James1115
Wilton, Ct
Post Number: 3178
I also thought of that too Jonathan if he had it wired in parellell that would describe his problem right there.
any ideas
i have wired it both ways 3 ohm and 1 ohm. and that i mean by biger system now iam running 2 15 and a 1600 watt ppi.
