HU's 50W+
Username: Tdbdrummer
Post Number: 341
Are there any HU's that have higher than 25RMS/50MAX? I would like to have one if so!
Username: Carguy
Post Number: 3057
Yes there are some out there. One of them had 50w rms x 4. However, the extra power didn't justify the huge increase in cost.
You do know that HUs can't deliver clean power right? So even if you were to find one 50w or higher, it'll contain lot of unwanted noise.
Post Number: 342
Oh, ok.
Username: Videobruce
Buffalo , NY
Post Number: 28
"You do know that HUs can't deliver clean power right?" Clean as compaired to what, a expensive separate amp? How clean can you have in a vehicle??
Buffalo , NY
Post Number: 29
BTW, doubling the wattage is barely noticeable anyway correct?
Username: Msully701
Stratford, Connecticut US
Post Number: 160
isnt there a pioneer HU out there thats 60wx4?
Username: Illuminator
Post Number: 429
Even if there is, that's most likely only maximum power...
and doubling wattage is very noticeable...
Username: Msully701
Post Number: 167
http://www.crutchfield.com/S-KOc1BIwsvgP/cgi-bin/ProdView.asp?g=62700&id=feature s_and_specs&i=130DEHP80M
27rms watts, im not saying its good just saying they do exists
Username: Carguy
Post Number: 3183
Videobruce, HU's amp is low quality. It may say 25w rms, but it'll distort/clip before it reaches the maximum rated power. You will also not get clean sound, especially the lows and highs. The only thing good the HU's built in amps can do is power low wattage mid range speakers.
Buffalo , NY
Post Number: 46
That should do me fine as that is only what I have.
