Setting Up Hifonics Amp
Username: Rickeyd87
Post Number: 20
ok i got a Hifonics TX1005D amp and a RE SX15...i just need help setting the -Sub Sonic- -Bass EQ- -Low Pass- -Phase- and -Level- .... I got the -Level- turned half way up and everything else is a quarter the way up...dont really know what all them things do so can someone help me.
Username: _andrew_
Post Number: 39
Sub Sonic filter cuts off inaudible frequencies. Usually <20 hz.
Bass EQ sounds like a bass gain. Increses your bass response at a given freq.
Phase is how the subs fire - don't need to worry about it if you only have 1 sub. This would be used to make sure that 2 subs would be firing at the same time.
Level is your gain from your deck. This should be in v, yes? Check to see what the Pre Out voltage is on your deck and set this accordingly.
