New System, what should i get
Justin Richardson
Im not really as knoledgeable about all this stuff, but im looking to get an Amp, some Subs most likely two 12's, a head unit and an enclosure for around 1500. Anybody have any thoughts on what i shoud get. And by the way i want the sensitivity rating to be high.
Username: Msully701
Stratford, Connecticut US
Post Number: 95
just for subs, an amp, box, and a HU if you use ebay to shop which is basically 50% off new equipment you should have no problem getting anything you want for 1500. look up subzone on ebay for sub boxes there very sturdy and very good quality. when shopping on ebay make sure its new and not "refirbished"
Justin Richards
But what type of subs and amp should i get.
Justin Richardson
And also what do you think of the Alphasonik PSW812?
