Rockford t112d4
zinge
i just purchsed an mtx 81000d amp, and am going to buy two t112d4 subs. i was wondering if it is ok to run the amp at 2Ohms when the subs are 4Ohms? if its alright how would i wire it?
Username: Invain
Michigan United States
Post Number: 2531
You can't. If each sub is dual 4 ohms, then when you wire them both together you can only get a 1 or 4 ohm load.
zinge
oh alright thanks. is there any way to get the amp to 1 ohm?
