Eclipse Subs Ohm Rating
Username: Velk4425
Post Number: 26
Greetings,
In my search for subwoofers, I came across eclipse subs. On their website, the dual 2ohm voice coils are said to be 1.8 ohms according to the spec sheet.
For example:
http://www.eclipse-web.com/sw7100/sw7124.html
Now if I get an amp that is 1-ohm stable, and I hook up two subs, is .9 ohms going to be a problem? Or is that how most subs are?
Thanks,
Eric
Username: Velk4425
Post Number: 27
Actually, let me rephrase that.
Lets say I hook up two dvc 4 ohm subs, which actually are 3.8 ohms according to the site, will .95 ohms in parallel be ok on a 1 ohm stable amp?
Username: Invain
Michigan United States
Post Number: 2474
Yes, subs are never made with voice coils that are exactly 2 or 4 ohms. They just round the numbers.
