Sub advice
Username: Krazzyboy44
Post Number: 13
are pioneer premier good subwoofers
Username: Mhamilton1
Ny Us
Post Number: 15
no
Post Number: 14
why do you think so?
Username: 54danny54
Post Number: 259
actually...yea...sum r
Post Number: 15
which ones are good?
Username: Mikechec9
Chicago/atlanta
Post Number: 19
install is going to make the majority of difference no matter what sub you choose. so, can the pioneer sound "good"? relatively speaking, yes. with proper installation. can they sound as good as a high/higher quality sub installed as well or better? no. and there are quite a bit of better sounding (not necessarily expensive) subs.
