Are the PPI art series amp good
loud and low
I am looking into buying a PPI Art Series A1200 for around 300 dollars. i have heard some good things about them but was interested in hearing about it from someone else. is that a good deal for one in good condition and are they powerfull and very clean sounding amps. thanks
Username: Tbone
OK United States
Post Number: 85
Yeah, they are good, the older ones were really good, but I do not about the price? Hopefully someone else can clarify if that is a good price or not.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 1479
the Art series amplifeirs are fantastic.
some of the best amplifiers you'll find for mids/highs.
I'd buy it, myself.
loud and low
hey thanks for the help. do you know if they have internal crossovers or would i need an external one also glass you sayed they worked best for mids and highs? i willn't need 1200 watts to run my highs so will it be good for subs or is that just not what it was ment for? also would i need any other external signal proccesing stuff since its so old and doesn't have all the other features of the newer amps. thanks again for your help.
Username: Glasswolf
Post Number: 1491
you can use it for subs.
if your head unit has sub pre-outs with its own crossover, you shouldn't need anything else.
