Replacing Laptop For Cd Player
Kyle M
As most people now days, i use mp3'z at home for music as it gives more varity then cd's. i was thinking of getting a laptop, buying a power converter for and using this as my music source in my car. also wat i wanted to do is remove the lcd from the laptop and mount it elsewhere to watch movies etc. i was wondering if its possible or a lame idea. i no that i will probably need a better soundcard as most standard laptop soundcards give off crap sound.
Username: Fastbastard1977
Lousiville, Ky Usa
Post Number: 10
no its not lame i put one in my brothers car mounted it under the seat and put a 7 inch touch screen in the dash to contral the lap top
Username: Zootreeves
York, Yorkshire UK
you could probably do it without having to dissmantle the laptop if you got a tablet pc (http://www.pcwb.com/servlets/Catalogue?item_code=ACETAB06&shop=PCWBD&speedtrapid =pcwbfroogle)
Kyle M
im on a real tight budget so i doubt i'd be able to afford touch screens, do u hav ne other cheaper idea's that could help?
