Subs and amps
Username: 98neon
Ok im looking at the ABP102T audiobahn bandbox: 2 10' subs. Powerhandling 100-600 watts RMS. 1200 max power. What kinda amplifier would i need to power it to produce good bass. On crutchfield it has the audiobahn A8000T which is 800 x 1 @ 2 ohms
would that be enough to power it?
Username: Insearchofbass
Post Number: 1968
yes but you can prob buy that amp cheaper on ebay
Username: Mr_wiglz
ManchesterEngland
Post Number: 32
what configuration are the subs connecected in, and what impedence will they be showing to the amplifier? I'm guessing it would be a 4 ohm load. in that case you will need something that will give out 600 watts rms
Post Number: 1970
if they are single voice coil 10s each you will be at a 2 ohm bridge
Username: Mr_wiglz
ManchesterEngland
Post Number: 34
I think the subs in the bandpass enclosure are probably like the mtx subs with a single 8 ohm voice coil.
But of course, we need to know specifics of the products before we can help, you can;t just expect us to know the product.
Post Number: 1972
audiobahn says 4 0hm stereo hook up so id say were safe with the 2 ohm at bridge (meaning they are 4 ohm single voice coils)
Post Number: 1973
you cant use the 8000t its not 2 ohms stable mono bridged from what i see
Username: 98neon
this is all i can find about it: DUAL ANGLE 10" TUNED
BANDPASS SYSTEM
High Quality MDF Construction
Black Suppleather Covering
3/8" Plexiglass Window
Blue Interior Neon Lighting
Mirrored Interior Panels
Dual 12" PHAT 2" Foam Surround,
Non-Pressed KM3(tm) Coated
Cone Subwoofers
50 oz. Strontium Magnet
2" 4 Layer ASV Voice Coil
Bumped Back Plate
Extended & Vented Pole Piece
Gold Binding Post Terminals
Power Handling: 600 Watts RMS
Sensitivity: 103dB
Frequency Response: 32Hz - 150Hz
Impedance: 4 Ohm Stereo
Dimensions:
13"(H) x 29.5"(W) x 16.75"(D)
Post Number: 1974
whats you spending limit for an amp?
Username: Adelphia83
Colorado Springs, CO USA
Post Number: 25
Bad choice of subs IMO, those manufacturers build those bandpass boxes for pure SPL, they just don't sound good at all no matter who you buy it from.
Are you flexible on the subs? If so, the amp you mentioned is damn good for the price, but you can't use it in a 2 ohm mono load. If you had something like dual 4 ohm VC woofers, or single 2 ohm, you'd be set.
