2 channel or 4
RonMexico
Probably a basic question, but if you have front speakers and a sub to power is it better to have separate amps or by a 4 channel and bridge 2 outs for the sub. Also taking money into consideration, is one that much better than the other? Thanks
I would go with separate amps, but if you want to save money you can just get a 4 channel. It mainly depends on the speakers and the watts it can handle.
