Kenwood KDC-715S
Username: Recordgod
Newbie here. I searched and found this thread, https://www.ecoustics.com/electronics/forum/car-audio/130573.html which sounded like my problem except that it just stopped. Working fine then opened half way and then nada. I hit the reset and it starts to close but then immediatly returns to the previous state.
I took it apart and tested the cable but it seems to have continuity. Anything else I can try? I really don't want to replace the unit because a) I am BROKE b) I really really liked this unit.
Username: Illuminator
Post Number: 611
You could possibly still try replacing the cable. If I remember correctly it isn't more than 10 bucks.
And if you're really poor, i'll sell you a new headunit for cheap, heh. Or you can always check ebay and see what they have.
