Box building... port vel?
Username: Sevin7
Post Number: 105
my user manual says make the port 4x 7.25, and it says 19.6 for port VEL, what is port VEL? Also that means 4inch diameter and 7.25inches long right? im going to use pvc pipe, should work right?
Username: Basshd
Post Number: 19
Yes just make sure the edges are rounded and you'll be fine. Port vel is the speed of air in a port, usually expressed in ms(milliseconds) and varies with power and frequency, in other words a 100 watt amplifier will cause less port velocity than a 500 watt amplifier. The goal i like to shoot for is to stay under 23ms when the sub is placed in a trunk firing backward, and under 17 ms when placed in a hatchback or suv. The higher the port velocity you have the more of a chance you will hear "port noise" or the "chuffing sound" associated with a high port velocity. The more area you have for the port the less port velocity you will have, but the port will have to be longer to keep the same tuning.
