Need help looking for a box for my subs
Username: Iufan4lifeul
Louisville, Kentucky
Post Number: 9
I have 2 12" Sony Xplod 900max/300RMS subs in a box right now. I went to an audio shop to have the system installed. The guy said that the box was not designed for my subs and I was losing SQ and SPL. Would I notice a big difference if I got a better box? I found this one... http://www.sonicelectronix.com/item_952.html
but I don't know much about them so could you tell me what you all think? Thanks
Post Number: 10
can anyone help??
ThatGuyYouKnow
yes that will do fine, Besure to line the box on the inside with polyfil. best 7$ you could spend, you can find it at your local wal*mart in the sewing/crafting department.
1 lb per chamber.
Post Number: 11
how much louder and better will a box that is tuned for my subwoofers sound? And what does this polyfil do that you talk about?
