Amp for Atlas 15"
Username: Algirard1
OH United States
Post Number: 105
I will be ordering a 15" Atlas tomorrow. I am trying to decide on an amp to get for it. i was thinking of getting a 4 channel amp and using two channels to run some components and bridge the rear to run the Atlas. I was thinking of getting components that are around 100 watts rms. What 4 channel amp would you suggest?
Username: Algirard1
OH United States
Post Number: 106
would this be a good amp?
http://www.woofersetc.com/product.asp?0=362&1=363&3=2164
Username: James1115
Wilton, Ct
Post Number: 2770
too much power for an atlas! 500 watts is way too much.
Username: Algirard1
OH United States
Post Number: 107
what amp would you suggest?
Username: Algirard1
OH United States
Post Number: 108
I just ordered my 15" atlas today and now I need an amp to power it. I am looking for a 4 channel amp that I can bridge the rear chanel to power the sub and the front channel can power some speakers. Any suggestions?
Username: Fishy
Tamarac Ft.Laud, FL USA
Post Number: 1200
I think that T1004 would work ok. That 500 watt rating is the mysterious "dynamic power" at 14.4 volts. Its 360 watts rms at 12.5 volts bridged into 4 ohms and 90x2 at 4 ohms stereo.
If you're worried about it go with the T684:
http://www.woofersetc.com/product.asp?0=362&1=363&3=2163
You'd get 240 watts to the Atlas which should be plenty and 60 to your components.
-Fishy
Username: Fishy
Post Number: 1201
Thsi would work too:
http://www.etronics.com/product.asp?stk_code=kic04kx6504&store=&catid=307
