New member Username: Blitz666Post Number: 1 Registered: May-05 | Ok i really need help with this.. i been trying to find a solution for over 1 month and havent seemed to be able to find one.. So here is the Problem.. Im running a Pioneer DEH-p5650MP head unit and 2 amps.. 1 mono block just for the bass) and one 4 channel for my speakers.. My problem is that When i turn my head unit on, it makes Really stupid noised.. It sends constant THUDDING Noises to my speakers and sub.. when i move my head unit around while its on it makes static noises, when i tap the RCA cables at the back of the head unit u can hear it through the speakers and sub.. but i never seemed to have a problem until i disconnected my RCA cables out of the SPEAKER AMP while it was playing ( and yes i know that was stupid )... could it be that my head unit is damaged?? coz i changed my rca cables and i still get the same problem.. Also.. it makes a fast TIC tIC TIC TIC noise at times.. from what i know, i havent changed any cables around that could cause this.. even when the car is off.. i still seem to be getting what appears to be engine Noise.. ANY HELP Would be great..!! |
Silver Member Username: IlluminatorPost Number: 222 Registered: Apr-05 | You would be best off looking at this: http://electronixwarehouse.com/education/accessories/aboutnoise.htm I'm guessing that you might have your power wire too close to your RCA signal wire somewhere in your car. |
New member Username: Blitz666Post Number: 2 Registered: May-05 | well, i got my head unit checked out by the place i got it.. they reckon that the RCA on the back of the head unit HAS BEEN used up and has been damaged.. i gotta wait and see what happens//. thanx |
