Does dynamat increase bass
Username: Car_bangs
Post Number: 70
i have never used dynamat in car what does it do for you i know it would keep bass in your car on the e way but does it make it louder
Username: Insearchofbass
Post Number: 1771
yes it can make your car louder just the mere fact that it insulates your car from outside noise is a gain because you hear more of your tunes you paid for but doing that can get expensive
Post Number: 1772
are you doing those 4 15s?
Username: Car_bangs
Post Number: 75
dont know yet im looking at a lot of shet
Post Number: 1773
do you have aim i want to talk with ya a bit
Username: Car_bangs
Post Number: 76
cerwin vega, another l7 15, the four 15's, some spl, jl, alls sorts it just so hard 4 me to pick
Username: Solacedagony
New Jersey US
Post Number: 396
What dynamat does is make your speakers more efficient. It stops parts of your car from vibrating. Vibration is a conversion from energy to heat, so in eliminating vibrations, you're making your speakers more efficient/louder.
