What is the best EQ to buy?
IM considerng a seperate EQ to buy. ive looked at eclipse and phoenix gold. which is the best out there?
Username: Glasswolf
Post Number: 252
Audiocontrol
www.audiocontrol.com
that's probably one of the best makers for signal processing you'll find without going to proprietary setups like Zapco.
ppi deq230 1/3 octive I found it on etronics.com for $335 zapco is go to.
Username: Ereed
I have a ppi deq230 and I absolutely loved it. I'm debating on what to do....I accidently fried it at a world finals usac show few years ago and I'm not sure if I should send it to ppi to fix it or sell it to someone cheap and have it fixed. If I can get it fixed cheap then i would install it back into my next future system. What you guys think I should do?
