93 Grand Am coil problems?
Username: Jordanh420
Hey, will running a system in a 93 grand am mess up the coils that run to the spark plugs? My car wont idle but when i hit my gas it will run. when it idles, it runs shaky and stalls. any help would be appreciated.
Username: Tim_9872
If this happened before you hooked your system up it could be a ton of different things. If you have a V6 or anything else for that matter you may have a lose spark plug wire which would cause it to run shaky at idle and not that bad at higher rpms. Try the spark plug wiring first.
