***SOUNDSTREAM JUNK?????? ***
Username: Vayoboy20
VA-DC USA
Post Number: 11
Soundstream used to make top notch amps but some of you are saying the new ones (van gogh) are complete junk. The power and features look great plus the ability to easily tune the amp since all the adjustments are on the front. ARe these new soundstreams really that bad??? Thanks for any knowledge!!
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 710
Its all about the build quality man. They used to be really good amps, but the build quality has slipped to next to zero.
Username: Fishy
Tamarac Ft.Laud, FL USA
Post Number: 1139
You can still find a few of the Rubicons out there new. I own a 300-2 and am completely satisfied with it.
-Fishy
