Soundsplinter audio
wat are your thoughts on this brand and wat other brands are compareable to soundsplinter audio
Username: Jmloughrey
Farmington, CT
Post Number: 1246
look like pretty damn good subs...
Username: James1115
Wilton, Ct
Post Number: 2684
yeah they have gotten great reviews, if you want some info on them talk to Hunter he knows a good amount about them.
the one im talkin about in particular is the new rl-i 8" sub becuz thats all i can fit in my truck but they just started sellin them so idk if anybody know anything about them
well i jsut went to there site and it says they come out on the 29th but on there site it wont let you buy them yet so wats up wat do i do?
Farmington, CT
Post Number: 1256
wait a couple days...
Username: Hdubb
Farmington, Nm Usa
Post Number: 1369
well they are actually based off of tc sounds subs, and they will be using a watered down LMT motor coming pretty soon so look for it
Username: Loudnobnoxious
Post Number: 132
yep
35mm x-max drivers coming from SS, should be a tad over 1k rms. LM Technology really makes a world of difference. I know the inductance on my LMT is around 4mH and it still plays well up to about 60hz or so.
price for the 15" will probably be $700
