Sub help
Username: Limppimpin
I have 2 visonik v109d6 10in 1200w peak 600w rms subs and im working on making an encolsure for the. what i want to know is if i should go ported or sealed (they will be in a trunk). also they say the max size for a sub box for them is .65cuft so is the max size for a box for 2 subs 1.3cuft or can i go bigger. also for wiring them i can use series/parallel @6ohms or parallel @1.5ohms wich is better.
also i could you sujest what type of amp to runs the 2.
thanks
Username: Subfanatic
Walton, Ky
Post Number: 3234
are they DVC 6 ohms???, cause you could just use an amp that is stable down to 1 ohm, then estimate what its power would be from 2ohms to 1 ohm.....but for the enclsoure, what do you mean the max size is this, is that what the subs say, or thats what is limnited to your trunk???
they are dvc 6ohms. and for the enclosure if its sealed the book says a max of .65cuft
