Bronze Member Username: Whiteaurora01Post Number: 24 Registered: Apr-05 | I have four 2 ohm dual voice coil 12inch kicker L7's. I will be running them on a new BD1000. When the shop installed them they ran it in series. But I know they will be much louder if i run them in parrallel. but is it safe for the woofers and amp. (the bd1000 is a mono amp and 1ohm capable) |
Gold Member Username: InvainMichigan United States Post Number: 2166 Registered: Aug-04 | http://www.jlaudio.com/tutorials/wiring/#4dvcsp |
Gold Member Username: James1115Wilton, Ct Post Number: 2740 Registered: Dec-04 | you have no other option but to run them is series parellell unless you want to cook your amp really really fast! |
Silver Member Username: Addicted2bassMiami, FLORIDA USA Post Number: 606 Registered: Nov-04 | yeh beacuse if you run it in parrelel doesnt that mean you're going to be pushing them at like .25 ohm load. |
Bronze Member Username: Car_bangsPost Number: 26 Registered: May-05 | .5 |
Bronze Member Username: Car_bangsPost Number: 27 Registered: May-05 | insnt the lowest 1 ohm |
Silver Member Username: DankmanGranger, Indiana United States Post Number: 134 Registered: Jan-05 | You can do it, my buddy had his at .25 ohms on his MTX 1501D amp. |
Bronze Member Username: Car_bangsPost Number: 29 Registered: May-05 | well let me know what happens |
New member Username: Ridinlow987Post Number: 1 Registered: May-05 | Hey i have 2 15'' audiobahn high ex. and they are duel 4 ohm and the only run 2 or 8 ohm and i have an amp that only runs at 4 ohm and right now i have my subs wired up at 4 ohms and i was wondering what is gonna blow first the subs or the amp ( i had the subs hooked up like this for about 3 weeks now ) |
Bronze Member Username: Car_bangsPost Number: 32 Registered: May-05 | well that means u have a 2 ohm load and if your amp is 4 ohm stable your unstable wire both your subs at 8 ohms and bridge them to make them 4 before u do any damage to your amp |
New member Username: Ridinlow987Post Number: 2 Registered: May-05 | ok cool thx for the help |
Gold Member Username: SubfanaticWalton, Ky Post Number: 3267 Registered: Dec-04 | freedom, there is no limit to the lowest amount of ohms |
Silver Member Username: Dpaw20FL USA Post Number: 174 Registered: Mar-05 | could there be -ohms? |
Bronze Member Username: Whiteaurora01Post Number: 28 Registered: Apr-05 | so is a .25 ohm level safe for a new bd t1000?? |
Gold Member Username: SubfanaticWalton, Ky Post Number: 3270 Registered: Dec-04 | DPW No, thats not possible, because think of it like this, when your messing with ohms, every time you HALVE an ohm, you DOUBLE your POWER, so if u have taken algebra, or math in general lol, you know that if u keep halving somen you will keep just getting a smaller number, never ever reach zero but get close but keep going, and if u cant reach zero you cant get to negs |
Gold Member Username: InvainMichigan United States Post Number: 2171 Registered: Aug-04 | Mike, no, .25 ohms is definitely not safe for that amp. I've personally never seen an amp that can go blow .5, and then again they are top quality amps. I've never heard of people running below .5 ohms either. Can you imagine how hot the amp would get running at .25 oms? Why would you even want to try it? |
Gold Member Username: FishyTamarac Ft.Laud, FL USA Post Number: 1127 Registered: Sep-04 | Dayum, Sub I'm impressed. You're exactly correct. A perfect amplifier designed and built by the Almighty himself would produce an infinite amount of power into a 0 ohm load. Can you say "Big Bang"? hehe -Fishy |
