Wiring mono for 2 ohms?
Username: Crusacargen
CA US
Post Number: 14
i know this sounds silly but im trying to wire my mono amp for 2 ohms. I am running 2 4-ohm subs to it. I think the way to to dit is by wiring pos of each speaker to pos on amp but not sure cuz someone told me to wire it another way. Please help
WC
Yes, connect the poss from the sub to the amp amn the neg to the neg to the amp, since mono amps are 1 channel, stack the 2 poss and the 2 neg on the amp.
WC
Look at this picture.
http://pic17.picturetrail.com/VOL809/3228131/6595604/95438858.jpg
CA US
Post Number: 15
is this really the way to do it because to me it seems wrong maybe because I havent seen the setup. Please gimme more support.
CA US
Post Number: 17
can someone show me a normal 4 ohm load
Username: Shocksyde
Post Number: 7
i have a dual voice coil 4-ohm sub and have it wired like they say above and it presents a 2 ohm load.
pos of each sub to pos on amp, neg on each sub to neg on amp.
done.
While we are on this topic...could someone draw me a diagram of how I would run 2 4-ohm single voice coil subs down to 2 ohms from a mono amp
Username: Cenus
Hicksville, Ohio Usa
Post Number: 84
http://www.jlaudio.com/tutorials/wiring/index.html here this site might help
Username: Jhick8
Post Number: 34
So I can just run each wire from each sub to the same port on the amp?
So can I just put both positives into the same port on the amp?
Username: G3nocd3
San Jose, Ca USA
Post Number: 96
i wouldnt. Id run one wire to each sub and connect accordingly from there. I dont like runnin multiple wires into one connection on an amp. Lazy way to do it. And less connection. Unless you solder them together. :-)
