Speakers speakers, what to do blah blah blah
Username: Blackviolet
I'm sure all the questions you get like this get old. Sorry. = /
OK, I have a '99 Toyota Solara SLE. It has like 8 speakers.
I listen to just about everything from classical to rap to hardcore punk/metal. I want something that will sound great for it all. I have a good budget. What would be the absolute best for me? I was thinking JL Audio -- what do you think? Should I buy a component kit? Should I get 2 W7's, or would that be overpowering? Just one? What about the Cerwin Vegas V-Mags for the 6x9's? Or should I do it all JL? Or is there something even better (without being TOO ridiculously expensive) for me? With that many speakers, will one amp do it, or do I need two? Which amp(s)?
Which deck?
What is SPL?
Thanks!
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 372
OKay Desiree, hears the deal. You're only going to actually need ONE set of components, and an amp to power those. Just unhook all the other speakers and run the front 2 doors, it would sound the best. Secondly, the W7 is a badass sub, and one of them would do it. As for the deck that is a personal opinion, just go to your local audio store and check out as many as possible, find one you like, ask that store to match the online price if they do, buy it, if they don't get it online.
For a component set, look into CDT, Infinity, JL, Boston, MB Quart, and Dynaudio.
You'll need a 2 channel amp to power those speakers. Something from PPI's Art Series PC/PCX series would do nicely.
If you can afford the W7, I would get it, and pair it with 1000/1 or JBL 1200.1, or Hifonics BX1000D
i cant get my speakers to work
babybooty85
i hooked up my cd player and only one speaker will work my 6-9 in the back,and it is scratchy what is wrong?
Username: Langner
Madison, South dakota US
Post Number: 98
i had a cd player like that...except no speakers worked...i just bought a new deck and it worked fine
Username: Langner
Post Number: 101
that one speaker could be underpowered 2..but i dont know much bout spekears jus a guess
Username: Montster92
I would really like to know if 6*9 speaker boxes must have breathing holes in them so that the speaker can reverberate better in them. Therefore having a bit more bass.
